Hi
please help with the wiring
i have read through the forum didnt find any info on my 3 way configuration
attachment is my 3way configuration at home
i put my GE12722 on the left box and GE12723 on the left
i was able to make my 12723 add on switch to control my 12722 main switch on/off
but no matter what i do i cant make the light come on/off i think the reason is on the right side of 12723 box there is 3 cable and i only able to connect 2
You’ll need to change how the wires are connected at the lights. Your preexisting configuration has the load running from the left switch to the right switch and then to the lights. You’ll need to reconfigure so that Load terminates at the lights and only Neutral and Traveler extend to the right switch.
Timely discussion… i just pulled apart some switches in my house and was going to replace them with this same combination. unfortunately, it looks like i don;t have a neutral wire between my switches. Am i s.o.l. or is there a way to use use these switches here (see diagram)?
Assuming that all three marettes and the left-hand switch are in the same box, you should have no problem getting it to work with the GE switches…
With reference to your diagram: For the switch on the left-hand side:
remove marette from black/black bundle in lower left corner… Connect black from panel to GE Dimmer switch “LINE” terminal. Cap the remaining black wire (that goes to the remote switch).
Remove White from existing switch and connect it and one end of a short length of white wire to the bundled white/white/white. Use will probably need to get a larger marette. Connect the other end of the short white wire to the GE Dimmer “NEUTRAL” terminal.
remove the black wire from the existing switch and connect it to the GE Dimmer “LOAD” terminal.
remove the red wire from the existing switch and connect it to the GE Dimmer “TRAVELLER” terminal.
For the switch on the right-hand side:
remove the red wire from the existing switch and attach it to the GE Auxiliary switch “TRAVELLER” terminal.
remove the white wire from the existing switch and connect it to the GE Auxiliary switch “NEUTRAL” terminal.
remove the black wire from the existing switch and cap it.
Hi Z-Waver
on my basement i have another weird one
the panel actually go to first light then in that junction box only have 2 wires go to the switch 1
on the switch 1 box there is 3 wires goes to switch 2
the wire goes to switch one is weird because the hot actually is “WHITE”
i looked all the wiring seems the zwave switch need 3 cables and now i only have 2 available (no way to pull another cable )
is there a solution ?
[quote=“Yutaka, post:10, topic:191650”]can i use the ground as my neutral or load ?
as i only have 2 cables from the panel to switch[/quote]
Simple answer to this one.
[size=14pt]NO![/size]
One solution (not ideal in my opinion) is to mount a z-wave module in the junction box by the light and then use two z-wave wall switches with association to talk directly to the module.
Using association menas that they will work regardless of the state of vera but this is a costly method. You need to ensure that the wall switches support association as not all do.
@Yutaka - Never use a ground for anything but a ground. NEVER
Based on your description, you will not be able to use the GE switches in your “switch loop” circuit. But, you can probably use something like the Aeon Labs DSC26103-ZWUS - Z-Wave In-Wall Micro Controller to provide Z-Wave control capability to your circuit. See the attached diagram for how that would work.
