Need some help please. Vera3 with UI5
I have installed a GE HA01 duplex outlet and want it to control a lamp from Vera3 and a GE45601 remote.
How do you pair the GE 45601 remote to the Vera3…step-by-step on a Vera3 UI5?
How do I turn ON the lamp at DUSK and OFF at 11pm in Vera3. There is NO good information on how to do this step-by-step for UI5.
I also have a GE45601 remote that I want to use to turn ON the lamp with and preferably use the NUMBERED KEY CONTROL setup for key #1. Found a few posts regarding the remote but can’t get a simple answer.
I can get the GE HA01 outlet to work with a Vera3 manual command or the remote but not both together. I can include the HA01 outlet into the Vera3 and get it to turn ON/OFF the lamp but then cannot include the HA01 into the remote. If I exclude the HA01 from the Vera3 and include into the remote, the remote will work to turn ON/OFF the lamp but then cannot include the HA01 into the Vera3.
Any help is greatly appreciated before I trash this stuff.
With the old X10 modules you could turn on a lamp load and the X10 module would click ON…but not this Z-Wave stuff, thus the need for the remote. X10 may not have been 100% reliable but it was much easier to setup a working system.
Found this but it’s mostly for UI4:
http://forum.micasaverde.com/index.php/topic,4955.0.html
Here is more GE45601 info:
http://forum.micasaverde.com/index.php/topic,1960.msg7383.html#msg7383
http://forum.micasaverde.com/index.php/topic,9701.0.html
