Followed you suggestions… no luck… I am using The Honeywell Vista Alarm plugin. PLEG shows me the DetailArmState as a string under devices. It doesn’t seem to read it properly when it evaluates the condition. I am either doing something wrong or there is another problem.
I’ve posted the reports and log result below.
STATUS:
Triggers
Name Description Last Trigger State
TestTrigger Test Trigger is turned on 2013-08-16 10:15:54.136 false
Schedules
Name Type Time Days Last Schedule
Device Properties
Name Device Name Device Variable Last Change Value
AlarmStatus Alarm System DetailedArmMode 0 false
AmIHome Is iPhone home? Status 2013-08-16 10:15:06.954 0
Conditions
Name Expression Last True State
TriggerArm TestTrigger == 1 AND (AlarmStatus eq “Disarmed”) 0 false
Actions
Actions for Condition: TriggerArm
Device Action Arguments
Light High SetTarget newTargetValue=1
Report:
Triggers
Name Description
Schedules
Name Type Time Days
Device Properties
Conditions
Name Expression
Actions
LOG
08/16/13 10:15:54.135 luup_log:180: PLEG:180:TriggerPropertyUpdate:Status <0x32682680>
50 08/16/13 10:15:54.136 luup_log:180: PLEG:180:TriggerPropertyUpdate:Name:TestTrigger State:true Device:181 <0x32682680>
50 08/16/13 10:15:54.136 luup_log:180: PLEG:180:EvalConditions:Multi Trigger:TestTrigger <0x32682680>
50 08/16/13 10:15:54.139 luup_log:180: PLEG:180:EvalConditions:Condition:TriggerArm Trigger:TestTrigger Result:false <0x32682680>
50 08/16/13 10:15:54.140 luup_log:180: PLEG:180:SaveDB:{{name =‘TriggerArm’, state = false, seq = 0},{name =‘TestTrigger’, state = true, seq = 1376662554.1363},{name =‘AlarmStatus’, state = false, seq = 0},{name =‘AmIHome’, state = ‘0’, seq = 1376662506.954},} <0x32682680>
