Help to set up my VeraLite on my Home Network only!
HI all
I got my veralite working in my showroom office perfectly.
But now i need to demo the sistem in a farm that has no Internet! Only electrical power.
Will take all my Micro dimmers and use them as they are in my office!
I don’t think there is any special setup. Veralite doesn’t need internet to work. You just won’t be able to control it remotely since it won’t have a connection to the outside world.
You should still be able to connect on the local network (assuming there is one) and configure it etc.
[quote=“prim8, post:2, topic:182137”]I don’t think there is any special setup. Veralite doesn’t need internet to work. You just won’t be able to control it remotely since it won’t have a connection to the outside world.
You should still be able to connect on the local network (assuming there is one) and configure it etc.[/quote]
HI
When i connect to my secong network, WIFI only, my Ipad/iphone (Sq Remote App) doesnt connect.
Says device not found!
Make sure the app is set to local mode and is aware of the local network as well as the IP for Vera. Without internet, it will not be abl eto find it otherwise.
