help to find wall boxes
hi all !
I need import to brazil boxes to put 3, 4,5 and 6 switches in the wall.
I have found the wall plates…
but I need find the boxes to put in the wall.
someone have a dealer or website where I find it ?
our stand in brazil is differente from USA and zwave here is all imported products… and now I’m starting a big project using vera3 and switches leviton and GE.
thanks for helps !!!
grainger.com probably has what you are looking for. Not sure if they ship to Brazil though.
Thanks !!
I have an address in USA and the import process will be made for me. then some website is good.
I need boxes for brick walls not wood.
if someone have another site to compare I thanks !
but this one is very good !
If you have a US delivery address, try www.homedepot.com and www.lowes.com, the two big DIY store chains in the USA as well.
I’m very surprised by the price and the difficulty to find 5 gang boxes.
I find in smarthome 2, 3 and 4 gangs in quantity…I will don’t consider 5 gang in my project.
thanks one time more !
If you are going to have dimmers you might want to limit to 2 or 3 gang …
Dimmers generate a lot of heat … even the newer ones … There is usually no place for the heat to go … other than to get the dimmer warmer …
