Iāve been follow this and looking at Post 12 in which you post the results of the Config Settings.
What concerns me is that there is no return of Values for Parameter 33.
To me that indicates that there is no Para. 33 as Vera does return Values when Polled,
Several years ago after a discussion with an OEM in which it was admitted that they do not publish all Parameters that are used because it would require re-certification, I set out on a mission to log values for Parameter 1-120.
Needless to say most didnāt have a value but the unpublished ones did.
Observing your results, Iād definitely state that there is no Parameter 33, it is either a typo or it was never coded into the device.
What you could try is to retrieve the values from 1 to 40 and match them to the table, it might turn up an interesting result?
It could be parameter 8 an older model of the same device had a parameter 8 not 33 for that setting, according to the user manual I was sent and Iām not sure which model I actually have.
I dont know how to retrieve any parameter values for this device, monitor only doesnāt work in the GUI in device options.
Itās possible for it to be a write-only parameterāthe act of writing a value to it is what triggers the action. There is a parameter 34 that appears to function the same way with the opposite effect (disable the feature that 33 enables). This is also seen on other devices, notably the Aeotec MultiSensors, where writing parameter 255 with any value restores the unit to factory configuration.
Sometimes the values are not retrieved immediately, I have had to wait up to 24 hours to get values on some devices.
Look at it tomorrow, if there is no value indication then it is also possible that the device is faulty.
I can see what Patrick is pointing to as all values are the same and indicate a reset or set so the function is either ON/OFF.although why it is done this way is a mystery when normally you would use the same parameter with different values.
