Help replicating a Leviton VRCPG config in Vera
Hello,
I am a newbie here. Just got my Vera 2 and I am stuck with scene/area configuration.
My setup:
  • Leviton VRCPG as primary and Vera as secondary controller
  • one Zwave dimmable device with 4 dimmers and 4 scenes
  • one RZCS4 controller
Using my VRCPG I am able to configure RZCS4 so that button 1 activated scene 1, button 2 scene 2… at my Zwave device. I created a Profile with the following config:
Button: 1
Area: Area #1
Action: <Scene 1>
Fade: Default
Button: 2
Area: Area #1
Action: <Scene 2>
Fade: Default
I am trying to replicate this same setup in Vera and use my iPhone to control it. I can see and configure both the device and controller using UI4. The problem is that when adding a new scene I just have the option to add a COMMAND ON/OFF for the device and that will turn on all 4 dimmers.
Is there anyway to configure a scene that will send an command to my RZCS4 controller to turn scene/button 1 ON and OFF, another scene/button 2 ON and OFF, … ?
Thanks!
