Hello,
This is my first attempt at associating devices and I can’t seem to get it to work.
I’m trying to associate within Vera3 an Everspring SF812-1 smoke detector with an Everspring SE812-1 Siren
I can get this working fine as a Scene/Trigger but would like to get associations working also.
So for the smoke sensor:
- I went into Device Options/Associations
- Added Group Id = 1 as per the Manual
- Clicked SET then checked the Siren then SAVE.
- Message “Waiting for Wakeup to configure device” so I pressed the binding button 3 times on the smoke detector. - message went away.
For the Siren.
- I went into Settings
- Configure Node Right Now button - no errors.
Back to Smoke Sensor:
- Group Id = 1; Currently : 11 (11 is the ID of the siren).
- Hit the test button on the smoke alarm - the smoke alarm’s siren goes off but the associated siren’s does not.
What could I be doing wrong.
thanks,
John.
