PLEG:
Input Trigger:
Holiday Holiday Virtual Switch is On
Door Door Sensor is Tripped
Input Schedules:
SMT At Mondays and Tuesdays at 9:00
SW On Wednesday at 9:00
Conditions:
CaseA NOT Holiday and Door and (00:00:00; Door; 06:00:00)
CaseB1 NOT Holiday and Door and (SMT;Door < 8:00:00)
CaseB1 NOT Holiday and Door and (SW;Door < 5:00:00)
CaseC Holiday and Door
Notify can be imlemented as RunScene called Notify, or if the plugin you use for prowl has an action for sending a message it should be available in the Advanced tab for the Action.
In the Actions Editor go to the Advanced tab.
Where is says Pick a device, select the current PLEG device, then Add
Where is says Please select, select Run Scene
Specify the name or number of the scene. If you use a name, make sure it matches and is unique.
[quote=“RichardTSchaefer, post:4, topic:175795”]In the Actions Editor go to the Advanced tab.
Specify the name or number of the scene. If you use a name, make sure it matches and is unique.[/quote]
… that not initiative at all. Why can we not just simply choose a Scene like we choose a Device?
[quote=“garrettwp, post:7, topic:175795”]Richard is using MCV 's code to allow you to choose a device. MCV does not have a similar setup for selecting a scene.
Garrett[/quote]
gotcha. Of coure MCV does not have it, no one would ever want to trigger a Scene from a Scene… bunch of dumb azes.
