Help needed using PLEG to set Danfoss setpoint
I have just installed PLEG and would like to develop a scene to take the setpoint from a Dnfoss RS Z thermostat and then use that set point to set a Danfoss LC 13 radiator valve set point. Could someone give me some pointers as I am currently struggling.
many thanks
This is an excellent place to start to figure out how PLEG works: http://forum.micasaverde.com/index.php/topic,21603.0.html
Although not familiar with the Danfos. I would retrieve the temp from device properties in the RSZ.
Then use this in an Action in the LC13.
Look in the Advanced Option of the device you may find a.property that updates the Action when there has been a Temp change.
Thanks for the link. Will have a read and play some more.
Many thanks again
