i wished i could use your app as it seems really awesome but i can’t get it to work ![]()
I have a Vera 3 on firmware 1.5.622
I have a RFXCom Usb (plugin beta 1) to get temperature and humidity sensor on UI5.
my RFXCom is in the bottom USB plug
my USB stick in in the top USB plug
i installed datamine 0.979 directly from UI5.
then i want to configure it. so i lauch the plugin, go to “datamine graphing page”, configure the USB stick.
back to UI5, i click on “reload”
then back to datamine graphing page
=> nothing happens
i guessed i had to go to datamine configuration page.
i picked on of my temp sensor
i go to “temperature\urn:upnp-org:ServiceID:temperatureSensor1\currentTemperature”
i see that “display name” is blank so i put a name “temp room 1”
i reload everything.
now on UI5 the plugin says “channel =1” but in datamine graphic, channel are still empty…
if anyone could help, i’ll really appreciate
here is a quote of the log :
09 06/09/13 23:12:32.463 JobHandler_LuaUPnP::Run device 44 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xa37530 upnp: 0 <0x2ae35000> 50 06/09/13 23:12:39.893 luup_log:44: dataMine: Initialising dataMine System (0.979) __LEAK__ this:4096 start:593920 to 0xd25000 <0x2b769680> 06 06/09/13 23:12:39.893 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 1 now: 0 #hooks: 0 upnp: 0 v:0xb3d3b0/NONE duplicate:0 <0x2b769680> 06 06/09/13 23:12:39.894 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b769680> 50 06/09/13 23:12:39.895 luup_log:44: dataMine: Mounting to UUID '5891-A98F' <0x2b769680> 50 06/09/13 23:12:40.306 luup_log:44: dataMine: UUID = /dev/sda: UUID="5891-A98F" <0x2b769680> 50 06/09/13 23:12:40.323 luup_log:44: dataMine: Found UUID '5891-A98F' at '/dev/sda' <0x2b769680> 50 06/09/13 23:12:40.348 luup_log:44: dataMine: Mounted: /dev/sda on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) <0x2b769680> 06 06/09/13 23:12:40.348 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: /dev/sda now: /dev/sda #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b769680> 06 06/09/13 23:12:40.349 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: vfat now: vfat #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b769680> 50 06/09/13 23:12:40.413 luup_log:44: dataMine: D[40] S[urn:upnp-org:serviceId:TemperatureSensor1] V[CurrentTemperature] newVal on startup is 23.1 was 0 __LEAK__ this:32768 start:626688 to 0xd2d000 <0x2b769680> 06 06/09/13 23:12:40.414 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 1 #hooks: 0 upnp: 0 v:0xb3d3b0/NONE duplicate:0 <0x2b769680> 06 06/09/13 23:12:40.415 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b769680> 06 06/09/13 23:12:40.420 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 1 now: 1 #hooks: 0 upnp: 0 v:0xb3d3b0/NONE duplicate:1 __LEAK__ this:8192 start:634880 to 0xd2f000 <0x2b769680> 06 06/09/13 23:12:40.421 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b769680> 50 06/09/13 23:12:40.422 luup_log:44: dataMine: Startup complete <0x2b769680> 50 06/09/13 23:12:55.168 luup_log:44: dataMine: Delete backups complete - deleted 0 of 4 files <0x2c569680> 06 06/09/13 23:12:55.192 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskTotale[0m was: 1026048 now: 1026048 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c569680> 06 06/09/13 23:12:55.193 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsede[0m was: 32 now: 48 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c569680> 06 06/09/13 23:12:55.194 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskFreee[0m was: 1026016 now: 1026000 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c569680> 06 06/09/13 23:12:55.205 Device_Variable::m_szValue_set device: 44 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsedPcnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 __LEAK__ this:4096 start:663552 to 0xd36000 <0x2c569680> -2-=========================================================================== /dev/sda: UUID="5891-A98F" -3-=========================================================================== rootfs on / type rootfs (rw) /dev/root on /rom type squashfs (ro,relatime) proc on /proc type proc (rw,noatime) sysfs on /sys type sysfs (rw,noatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime) tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755) devpts on /dev/pts type devpts (rw,noatime,mode=600) /dev/mtdblock7 on /overlay type jffs2 (rw,noatime) overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay) debugfs on /sys/kernel/debug type debugfs (rw,relatime) /dev/mtdblock8 on /mios type squashfs (ro,relatime) none on /proc/bus/usb type usbfs (rw,relatime) /dev/sda on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) -4-===========================================================================Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytesDisk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 1054 MB, 1054867456 bytes
33 heads, 61 sectors/track, 1023 cylinders
Units = cylinders of 2013 * 512 = 1030656 bytesDevice Boot Start End Blocks Id System
/dev/sda1 ? 961892 956860 2142419640+ 45 Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(10, 255, 13) logical=(961891, 2, 48)
Partition 1 has different physical/logical endings:
phys=(302, 114, 50) logical=(956859, 25, 45)
Partition 1 does not end on cylinder boundary
/dev/sda2 ? 920601 1849504 934940722+ 65 Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
phys=(370, 10, 16) logical=(920600, 32, 35)
Partition 2 has different physical/logical endings:
phys=(357, 115, 51) logical=(1849503, 27, 45)
Partition 2 does not end on cylinder boundary
/dev/sda3 ? 845494 1657499 817283378 20 Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
phys=(357, 99, 40) logical=(845493, 13, 25)
Partition 3 has different physical/logical endings:
phys=(373, 112, 47) logical=(1657498, 24, 44)
Partition 3 does not end on cylinder boundary
/dev/sda4 ? 1433523 1433549 26464 d Unknown
Partition 4 has different physical/logical beginnings (non-Linux?):
phys=(370, 114, 37) logical=(1433522, 22, 25)
Partition 4 has different physical/logical endings:
phys=(0, 10, 0) logical=(1433548, 32, 4)
Partition 4 does not end on cylinder boundaryPartition table entries are not in disk order
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -5891-A98F
SetMountPoint -
SetManualMount -0
-6-===========================================================================
{“Version”:“0.979”,“dbVersion”:2,“Events”:{“count”:100,“last”:1370810736},“LastWrite”:1370812360,“Variables”:[{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:TemperatureSensor1”,“LastRec”:0,“Device”:40,“FilterMaximum”:0,“DrowsyError”:0,“Type”:0,“DataType”:1,“Id”:1,“FilterMinimum”:0,“FirstRec”:0,“DrowsyWarning”:0,“LastVal”:23.1,“DataOffset”:0,“Name”:“Temp Chambre”,“FilterEnable”:0,“Logging”:0,“Variable”:“CurrentTemperature”,“historyState”:0}],“Graphs”:[],“guiConfig”:[],“nextId”:2}
-7-===========================================================================
