I got a Vera3 and I have a StraightTalk Cellular Wifi Hotspot to be the router at my second home. Unfortunately, the hotspot does not have any lan plugs. I chose the Vera3 because the documentation states it can connect to a wifi router. I was able to set up my account, and get the Vera3 to connect to my first home’s network via lan. I did manual setup and typed in my network’s ssid and password, then I click the button and I saw a dialog box that told me to wait 5 seconds and then disconnect the vera from the router, and if need be reboot the vera3 and the router if they don’t connect. I unplugged the vera and tried accessing the dashboard. The dashboard downloads like the outside frame of the web page and it has a scrolling progress bar in the title window and keeps slidding like a barber pole. There a message that says to wait while it downloads. And that’s as far as I get. I’m practicing using my apple airport so that I can recreate the wifi set up steps for the wifi hotspot. Would you please provide me a link to simple step by step instructions as to how to change a vera3 configuration from using an Ethernet cable to connect to a router, to using wifi to connect to the router. Thank you in advance for your assistance with this matter.
I followed the instructions here and it worked for me. You need to be sure of the wifi settings and to not unplug your Vera too quickly.
http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Pro&page=Wifi_client_mode
