I need help, I just installed the EVL-3 to my home alarm system and I fell I am missing something. Hook it up add IP address and etc done. Please arm in the section to allow remote arming and etc. I have the PC1832, IT-230 and the Netgear ASG1000, apparently the ASG1000 works in the same manner as the EVL-3 but controlled by IControl. I need the system to move the zones over so I can see them (only see zone 1 and etc) control them in scenes. I know I am missing something in the setup any ideas or even point me into one of the 600 pages that I read?
I have the 6 zones and the Partition 1 on my system, will that ever change to my zones programmed in my alarm system?
If you meant the Zone Labels then no they wont update in Vera from what maybe programmed in the panel (EVL3 limitation). The only way to do this is to label them manually in Vera to match.
If you have more than 6 zones set up, then you need to configure the corresponding numbers in the plugin. For instance it by default will only show zones 1-6, however if you have more zones than that they wont show. Also if you only have <6 zones, but they are numbered with something starting from 7 etc, then the plugin wont see these unless you match the correct zone numbers.
Thanks very much for all of your support and just my luck, I purchased the EVL-3 this week and not a mention of the EVL-4. I have started running the labels in Vera, lots of typing 30+ sensors.
Thanks again,
Tim
Hi Again,
Thank for the help in getting started I have the zones setup and the IP address I the Vera plugin but it doesn’t do anything at all. I can arm(I place the word arm as per the plug in). I must be missing something the Evl-3 can arm and disarm but the plugin can’t. Any suggestions would be greatly welcomed.
