Hello everybody… I have a problem. I can t see the devices option of my dimmer device… i could see them days ago, but today i only see N/A in the zone device option … anybody known why I cant see them?
thank you soo much!
thank you soo much!
maybe you should attach a screen shot.
here you are.
As you can see, the sensors have ‘’?‘’ in the batery picture too. I saw in green color the level batery days ago too.
the next rime they are polled, they should update. This is ‘normal’ behaviour, por lo tanto no te preocupes.
how often are you polling the battery devices?
For example, today I have polled my door sensor, and later the picture batery continue with ‘’?‘’. ??? Are you sure that there isn t problem to My vera configuration?
What can you say me about my dimmers device option ? I want change the parameter N 7 and I can t add it. ![]()
What kind of sensor are you using? You may get some feedback here regarding that since it is likely that someone else uses the sensor too.
Same thing with the dimmer… What kind is it?
dimmer
FIBARO 211
Door sensor
Fibaro
