Help! I am new and cant figure this out!
I have been reading for the last 3 hours. I don’t know anything about the language that Vera uses and I need help.
Here is what I am trying to do;
I have a garage that I installed a single relay switch module and a man door that I installed a door contact.
I need to write a script that when the door opens, it turns the lights on.
When the door closes the light stays on.
When I open the door again, the light turns off.
Rinse and Repeat.
Thank you all for helping someone who has no coding skills out. Or maybe there is a plugin that is logic based that will allow me to select the specific parameters from the devices I want to use in a drop down? and allow for full logic (boolean) controls?
