Ok… I’m new to this home security/automation thing… but I have been doing a lot of research and I have some questions hopefully someone will be able to help me answer.
First, of all the systems I look at, I keep coming back to the MiCasa. So, I called them to ask a few questions and I got a guy on the phone of obvious Indian descent (his name was Chris!). He had no clue what he was talking about and the language barrier was really difficult. I asked to speak to someone else and they were just as bad. In short… I’m not very happy with MiCasa’s customer service from the start.
Enough bitching… on to my questions:
I would like a very simply home security system: some door/window sensors, motion detectors, etc. I want to self monitor and have local, indoor alarms/sirens go off when necessary. I keep being told that I need a home security panel and a home automation (i.e. micasa) system on top of it. For my simple home security needs, I don’t understand why I need the home security system. Can someone explain why a Z wave system won’t do the whole thing for me?
For a Z wave security system, how would I arm and disarm the system? I guess I can do it by my iPhone… but what if I don’t have my phone (or a key fob?) Can I incorporate a keypad? If so, which one?
I know I can monitor ip cameras… but can I record after an event? i.e. motion detectors while I’m away, record camera data?
Some security systems have an enunciator. They will announce when a door or window is opened. I like that. Can I do that with Z wave?
Is there a good solution to monitoring and operating a garage door with Z wave? Also, can my garage door opener cause a Z wave event such as when I open the garage door with my opener, it disarms my security system?
These are the first round of questions… I’m sure I’ll have a lot more!!
[quote=“JimboR”]Ok… I’m new to this home security/automation thing… but I have been doing a lot of research and I have some questions hopefully someone will be able to help me answer.
Thanks for any help!![/quote]
There is z-wave security system but Vera and devices are not by default a security system and you’d have to piece it together bit by bit. Can it meet that need, probably but it is the best value for money or as reliable as an dedicated system, I would say, not at all. It comes down to fit for purpose, fit for use. ZWave is short range rf communication. No ZWave keypad the same as an alarm system and Vera does not provide the same level of user security access as a dedicated alarm. You can have Vera announce things by include another series of devices such as Sonos and program this in but it is not a native function like you describe utilising an alarm system. People do do this and achieve their desired results but I would not take that route.
You can achieve all you desire with a DIY alarm system and integrate with Vera. There are several compatible brands readily available. You can self monitor and set up notifications via SMS and remote arm/disarm using both Vera or mobile app with some.
One of the most common systems being integrated is the DSC and EVL3. You can find an overview here.
I was searching the forums for pretty much this exact question related to why I need the alarm system and I’m still a bit stuck myself. For my purposes (a condo) I really just need 1 single motion detector, 1 door sensor, and 2 window sensors. As such if I were to stick a beefy UPS unit for my micasaverde unit I fail to see why I would benefit from an alarm panel / alarm system of any kind. I do see the DSC and Envisalink products and they are kind of cool, but I fail to see the point of them. Vera can already SMS/e-mail/etc, and can do so with multiple users. That is all an alarm company does anyhow, and given that there are three separate people that would receive the SMS messages, I’m not too concerned about not being able to get through and therefore the police never being called. With the UPS unit I’m not too concerned if the thieves were to cut power either. Thoughts?
Z-Wave is definitely the way to go. I’ve been using it for years and it lets you do so much!
I use it as a security system like how you described, but I’ve also figured out a few really cool tricks you can do with Z-Wave and wrote guides to help other people do them too…
I hope this helps! ;D
