I need some help trying to get a simple “Hello World” application working. I’ve created 3 xml files (see attached) all of which have been uploaded to my luup files. On the create device screen I specified my “D_HelloWorld1.xml” and “I_HelloWorld1.xml” files along with a description. The other fields I left blank (Device type, Internal ID, IP Address, MAC). After I added the device I reloaded the unit. Once it was refreshed I found that the device id for it was 12 so using HTTP get I tested it to see if I can get “Hello World” from the device.
“GET /data_request?id=action&DeviceNum=12&serviceId=urn:upnp-org:serviceId:HelloWorld1&action=GetTarget”
Whenever I execute this I keep getting “ERROR: Invalid Service” returned to me.
I use HTTP gets for all of my other devices and all work fine so I know it is something I defined incorrectly in one of these 3 files. I think I understand the structure but I’m a little foggy on what names I can use whenever I create a new service. I assumed that so long as it was unique and referenced properly in the I_HelloWorld1.xml file everything would work.
In D_HelloWorld1.xml I have defined the service using the following names. Is there maybe something wrong with the names that I chose?
serviceType = urn:schemas-upnp-org:service:HelloWorld:1
serviceId = urn:upnp-org:serviceId:HelloWorld1
D_HelloWorld1.xml
<?xml version="1.0"?>
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-upnp-org:device:testdevice:1</deviceType>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:HelloWorld:1</serviceType>
<serviceId>urn:upnp-org:serviceId:HelloWorld1</serviceId>
<SCPDURL>S_HelloWorld1.xml</SCPDURL>
</service>
</serviceList>
<implementationList>
<implementationFile>I_HelloWorld1.xml</implementationFile>
</implementationList>
</device>
</root>
I_HelloWorld1.xml
<implementation>
<actionList>
<action>
<name>GetTarget</name>
<run>
luup.variable_set("urn:upnp-org:serviceId:HelloWorld1", "Target", "Hello World", lul_device)
</run>
</action>
</actionList>
</implementation>
S_HelloWorld1.xml
<scpd xmlns="urn:schemas-upnp-org:service-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<serviceStateTable>
<stateVariable sendEvents="no">
<name>Target</name>
<sendEventsAttribute>no</sendEventsAttribute>
<dataType>string</dataType>
<defaultValue></defaultValue>
</stateVariable>
</serviceStateTable>
<actionList>
<argumentList>
<argument>
<name>RetTargetValue</name>
<direction>out</direction>
<relatedStateVariable>Target</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
</actionList>
</scpd>
