Hi all,
I have a RGBW strip that is connected to a Fibaro RGBW controller. When I tried to associate a switch with Groups 1-3 simulating inputs IN1 to IN3, I have no problems toggling the respective RGB channels with the correct colour. However, when I associate the switch with Grp 4 to simulate IN4, I can’t get the white channel to light up. Instead, it is the blue channel that comes on. Can anyone give me some hints/pointers on what I’m doing wrong? Thanks!!
The manual is here for info:
Not sure what you are doing here. Are you saying you are using a remote switch to associate with zones 1 to 4 in the Fibaro.
This is not what is meant. Association group 1 in the Fibaro means that you associate a remote device to your Fibaro so that when you operate IN1 it operates the remote device.
Apologies if I have misunderstood your question.
The Fibaro RGBW controller in its default configuration is such that each of its inputs can be used to control each of its 4 channels, and each input is correspondingly mapped to each of the association grp, i.e.
IN1 → R → Grp 1
IN2 → G → Grp 2
IN3 → B → Grp 3
IN4 → W → Grp 4
When I associate a switch to grps 1 thru 3, they all map correspondingly to each of the colour channels (i.e., RGB). However, when I associate with grp 4, instead of controlling W, it controls the B channel instead.
