Help about IPCAM Panasonic driver
Hello,
I try to modify FOSCAM driver in order to use green led as a pilot light to indicate camera in use or not .
I have read modified I_PanasonicPTZ.XML where are setup actions and variable initialisation but where is the corresponding JSON file, which, if I understand, contains the plugin User interface layout and links buttons to actions.
/etc/cmh-ludl/D_DigitalSecurityCamera1.json?
