Yes it is, but when I added the old one, I got 2 devices in UI7. With the new one only 1 (just On/Off)
I just changed the 3 lines as given in the first post. THen it becomes a smoke sensor. Even with battery. But when I push the test button, nothing happens in the GUI. It seems NOT to get tripped.
Thanks for your fast replies. Yes one device would be better. The old one added end 2018, gave me the 2 devices. And when I push the test button on that one, the icon blinks red briefly. Strance right? I will compare the vars in de advanced tab.
Yes I did reload both.
Also, pushing the test button won’t sent a notification. The old one does.
Looking at my original post, it looks like I added my smoke sensor in September 2019 and it only added one device for me.
Perhaps back in 2018 this device it was not included in the same manner as now and gave you two devices as you stated.
I have seen that happen with other Z-Wave devices like the Heiman door / window contact device, when I added mine, they did get included in to Vera as two devices and I had to do some manual work to make it one device only.
Firmware updates since you originally added the sensor back in 2018 may have some what improved how this particular device is included, as it gets included now as one single device not two devices as you noticed previously.
But clearly its not a fully supported device out of the box, or we wouldn’t need to change its device type as I described in the first post.
However this doesn’t explain why your new device now is not tripping correctly when pressing the test button. This should work.
Have you tested the sensor with real smoke?
When I first got mine I tested it by burning some paper and letting it smoulder near the sensor.
Likely however if it doesn’t trip with the test button a real world test won’t work either.
So is the replacement sensor also faulty?
Hard to say really, my sensor is currently working OK on the latest stable released version of the firmware for my Vera Plus unit.
Have you tried excluding the sensor and including it again?
How far away is the sensor from the Vera unit? Perhaps try testing it closer.
Didn’t test it with real smoke yet, will do that tomorrow. I also will open a support ticket.
So you added the device, it appeared as on/off. Then you only change the 3 lines and that is it?
And with the test button, the icon won’t become red for one second, but you get notifications?
I am getting alerts from Vera inbuilt notifications, both from preset modes notifications (giving category and subcategory params both set to 4) and device alerts. Also, untripping now works for me after change of device_json parameter from “D_SmokeSensorWithTamper1.json” to “D_SmokeSensor1.json”. I now have 3 sensors configurerd and all seems to work perfectly. Still on 1.7.4453, eagerly waiting for the new release.
For those having issues too, www.betaalbare-domotica.nl helped me to solve the issue.
First, this issue was introduced 2 firmwares back. So indeed it worked with me before and also with you guys. But maybe it is even different in the latest, as I changed the 3 device properties, but that is not enough anymore.
Solution
Under Advanced for the newly added On/Off device:
device_type : urn:schemas-micasaverde-com:device:SmokeSensor:1
device_file : D_SmokeSensor1.xml
device_json : D_SmokeSensor1.json
category_num: 4
subcategory_num : 4
Thought it worked, but not. Changed the Wakeup interval in Vera to 86400 as it is the default in the detector and turned off Automatic configure to prevent updates to modify the config. Since then I have 3 sensors waiting indefinitely on Wakeup. Tested the procedure with “Configure now”, remove battery (which will generate wakeup) and it worked for some minutes, and then on luup reload (?) the waiting for wakeup returned.
Sorry, I was unclear, 3 HS1SA-Z devices not sensors. Excluded one of the 3 devices and made my changes again, one by one and a wakeup after each change. Isolated the problem to the setting “Automatically configure”. Setting it to “No” will put the device in a “Waiting for wakeup…” mode for ever.
Waking up the device works but have no effect. I am using 7.0.31 and made the change to “Automatically configure” to “No” as of info in the Release thread to avoid reconfiguring of the devices on next firmware update.
Changing this setting back to “Default behaviour” on all 3 devices put all devices back to normal operational state, without need of excluding and including again, but after waking them up with the pin.
I also ran that code to set all devices to not automatically configure before doing the Vera firmware update. Its still set that way now after the upgrade and my Heiman smoke sensor hasn’t had the same issue.
Agree, at the moment all seems to work ok, apart for some unexpected “waiting for wakeup…” late yesterday, solved by the pin. Will have to monitor for some days to be sure.
Not that I’m aware of but I’ve never really looked into it.
If the siren can be triggered some how on the smoke detector manually then it would be easy to create a scene that when one goes off it sounds all the others.
