I don’t see the button anywhere?
Are you Looking for a button that says “HEAL”?
Because if you are that doesn’t exist in any verson!
http://wiki.micasaverde.com/index.php/Heal_Network
go to the 'Devices' tab on Vera's 'Setup' page, choose 'Z-Wave', then 'More Z-Wave Options' and hit the 'Go' button. In the section 'Repair My Network'
You might also have to be in the advanced area all the way on the bottom of the main page first then follow above.
Yes I thought it was Heal. I found Repair but it UI6 you have to go to the very bottom of the Devices page. There is a link for Advance Options which takes you to a UI5 looking section where you can do it.
Yup mentioned that in the last paragraph.
