In a closet, I have an Intermatic HA05 which has been paired to Vera successfully.
I’ve set up a scene where if my HomeSeer HSM100-S2 Z-Wave Multi-Sensor trips when it’s armed then the closet light goes on. This works, however, if I set a scene where the sensor is not tripped to shut the lights off in the closet - it doesn’t work. So, how does one shut the lights off?
I’m also having another maddening problem. I’m on my third Schlage FE599NX CAM 716 ACC 716 Home Keypad (starting to disklike these)d. First one had a mashed up battery compartment, the second one had faulty outside handle that would only operate on every 5th turn or so. The third one was installed a few days ago, it took about 2 hours to finally get the thing paired.
So… I set up a scene where when I enter my keypad # that the inside hallway lights come on. This has maybe fired once but nearly 30-45 some odd seconds after I’m already inside. It has not fired about 20 times that I’ve tested the door.
I am confused … is this two different closets ? Or did you replace the HSM100-S2 with the HA05 ?
Unless your Vera is very close to sensors … you need to do a Z-Wave Heal to establish the Z-Wave network. Note that battery operated devices do NOT repeat or participate in the mesh except as leaf nodes.
Do you have enough nodes (and in the case of Schlage) nodes that support beaming … to provide adequate Z-Wave connectivity.
The closet light that has the HA05 along with the motion sensor. When the motion sensor trips, I can set the bulb to on. I’d like to have the light go back to an off state when the trip clears. Is there a way to set that time, e.g. 5 minutes and then the lights go off?
I installed the InfoViewer plugin and there are 3 light switches next to the door, all Jasco’s that support beaming. They are all within 2 feet of the Schlage lock.
The closet I mention in 1) is where the Vera is housed and the HA05 does not support beaming - there are a couple of more Jasco’s light switches within 15’ of that area.
I’ve had some luck with the schlage triggering my scene though it takes about 5-6 seconds to fire. I was hoping for something around a second - enter my code in the Schlage and the lights come on in the hallway, perhaps fire up some music through my Squeezebox
I have around 20 light switches installed (most are GE/Jasco; wish I knew about instant status before I would have coughed up the extra cash) I probably have another 10-15 other z-wave devices throughout the house [motion, locks, heating, garage doors, keyfob, minimotes, etc]
I can perform another heal or should I look at moving the Vera outside of the closet?
You can have a scene (OR use PLEG) to trigger when the motion sensor is [b]NOT[/b] tripped.
Then for the actions you can use a delayed action to turn the light off N minutes after the scene is triggered.
You may not need a delayed action since most battery powered motion sensors will take at least 5 minutes before the motion sensor will indicate NO Motion after it was tripped.
