Has anyone successfully used a USB->multi-port serial converter?
Similar to this: http://www.amazon.com/Port-USB-Serial-Converter-RS232/dp/B00EIMVMSK/ref=sr_1_23?ie=UTF8&qid=1384204179&sr=8-23&keywords=multiport+usb+serial
I have 3 devices I want to connect via serial:
  • Lighting controller (LiteTouch)
  • 12 channel audio mixer
  • Elk alarm system
Instead of having a USB hub and a spiderweb of wires, this would be a lot more convenient. Also, if I had a bunch of single port dongles that were the same brand/model, how would I guarantee each one was always assigned to the same /dev/ttyUSBX device after a reboot?
The wiki page has one listed that works:
http://wiki.micasaverde.com/index.php/Serial_Supported_Hardware http://www.mcmelectronics.com/product/83-10137
Might be better off using one of these though since you don’t need to worry about things getting mixed up after a reboot:
http://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=47259&cm_mmc=GoogleProducts-_-WIZnet-_-Description-_-WIZ140/145SR-EVB&gclid=CN-LxafY3boCFcU5QgodW1cAeg
Has anyone successfully used a USB to serial mini converter from B&B Electronics with Vera?
[url=http://www.bb-elec.com/Products/USB-Connectivity/USB-to-Serial-Adapters/Mini-USB-to-Serial-Converters.aspx]http://www.bb-elec.com/Products/USB-Connectivity/USB-to-Serial-Adapters/Mini-USB-to-Serial-Converters.aspx[/url]
