Has anyone seen this error before?
CheckLogs: 23132
I’ve noticed this in my alerts every 5 minutes or so since 5/13. I haven’t had any recent changes to my setup that I can remember.
I’ve not seen it before, but it seems to occur shortly after a Log Rotation has occurred.
If you’re interested, on the Vera unit itself, under UI5, these are in the log file:
[tt] /var/log/cmh/NetworkMonitor.log[/tt]
and shortly after this is logged to their servers, there will be output like:
NetworkMonitor.log:02 05/29/12 17:15:16.102 NetworkMonitor: CheckLogs required handling <0x2b375460> NetworkMonitor.log:02 05/29/12 17:15:16.102 CheckForMemoryLeak CheckLogs was: 7249920 now 7335936 diff 86016 leak 294912 <0x2b375460>
I also have these CheckLogs messages. Any idea what causes this? Could this be a bug in a plug in? How can I fix this?
Part of my NetworkMonitor.log file:
02 01/14/13 21:14:23.665 e[33;1mFinished rotate logse[0m <0x2b048460>
01 01/14/13 21:14:55.938 e[31;1mReportError: succeeded URL: https://cms2.mios.com/alert?PK_AccessPoint=30102766&HW_Key=&LocalDate=2013-01-14%2021:14:55&Value=(none)&Code=nm_logs&Users=&AlertType=7&Description=CheckLogs:%205140e[0m <0x2b048460>
02 01/14/13 21:14:55.939 e[33;1mNetworkMonitor: CheckLogs required handlinge[0m <0x2b048460>
02 01/14/13 21:14:55.939 e[33;1mCheckForMemoryLeak CheckLogs was: 6840320 now 6926336 diff 86016 leak 630784e[0m <0x2b048460>
02 01/14/13 21:18:38.805 e[33;1mAutoConfigureNetwork: not fresh_install, exiting. Did 0=/usr/bin/Report_AP.she[0m <0x2b048460>
02 01/14/13 21:33:40.836 e[33;1mCheckForMemoryLeak CheckLU2 was: 6926336 now 6930432 diff 4096 leak 634880e[0m <0x2b048460>
02 01/14/13 21:35:42.190 e[33;1mCheckForMemoryLeak CheckLU2 was: 6930432 now 6942720 diff 12288 leak 647168e[0m <0x2b048460>
02 01/14/13 21:37:43.114 e[33;1mCheckForMemoryLeak CheckLU2 was: 6942720 now 6955008 diff 12288 leak 659456e[0m <0x2b048460>
02 01/14/13 21:41:45.774 e[33;1mCheckForMemoryLeak CheckLU2 was: 6955008 now 6967296 diff 12288 leak 671744e[0m <0x2b048460>
02 01/14/13 21:43:46.679 e[33;1mCheckForMemoryLeak CheckLU2 was: 6967296 now 6975488 diff 8192 leak 679936e[0m <0x2b048460>
02 01/14/13 21:45:47.866 e[33;1mCheckForMemoryLeak CheckLU2 was: 6975488 now 6979584 diff 4096 leak 684032e[0m <0x2b048460>
Mark
I’m getting this too. I’ve attached NetworkMontor.log as a text file since log is not an allowed file type.
There’s been no recent changes to my scenes, plugins or hardware. Yet then again, I only noticed this error recently. For all I know it’s been there a long time.
Plugins / Hardware
Yale Real Living Zwave lock.
Paradox EVO Alarm Panel Plugin (PRT3 Integration Module, using a USB connection to Vera)
DSC Alarm Panel Plugin (Envisalink 2DS via IP)
Radio Thermostat Wi-Fi Plugin (CT30 Wifi via IP)
My scenes include relations between the Lock, Paradox alarm, and Thermostat. Currently no scenes using the DSC alarm.
I am also having these checklogs events appearing. There is another thread which also involves this issue: http://forum.micasaverde.com/index.php/topic,13235.msg107987.html#msg107987
