[quote=“Chris H., post:11, topic:175093”]I have automated my house, my dad’s house and his wifes office building, here are some notes from what I have found.
Thermostat: I personally use the Trane for my house and 2 of them at my dad’s house, I used 2 of the Honeywell for the office and they all work fine.
Cameras: I would run an ethernet cable to the ceiling of each room in the corner and put a jack there. Then I would get a Netgear (FS728TP-100NAS) 24 port PoE switch. This switch can detect on each port if they need power and if so how much and send it to it. You can then use the Foscam 8910 PoE Version and only have a small network cable running from the back of the camera to the network jack in the ceiling, for camera’s that don’t have PoE you can use a $15 PoE Splitter so you take a network cable from the jack in the ceiling to the splitter and then it brakes out a ethernet data cable and a small power cable to the camera. If you can, always run a network cable to your camera’s, only use WiFi if you have no other choice. You can also use the Foscam 9821w which is a 720p H.264 camera, this will work with vera fine I have one connected.
For cameras you have 3 levels to choose from:
Cheap but Good - Foscam
Medium Prices and Really Good - Duhau
Expensive and Really Good - Axis
Surveillance: You can use something like the Synology NAS to record your video but you have to buy a license for each camera, this can get expensive. I use the BlueIris software which cost $49 and I put it on an old Pentium D computer I had in the closet, I have it do the recording and send alerts to my phone and Vera.
Lights & Fans:
Fans: you can use the INSTEON FanLinc like some others have done on the forums, I am about to do this as well. Don’t ever use a dimmer on a Fan, you will burn the motor.
Lights: you can also look at using the “Aeon Labs Z-Wave Smart Energy Switch”, these go behind your existing switch and can also report the energy usage. I have a couple of these and will report back after I install them this weekend. I use the Intermatic 600 Dimmers and you can actually use them with LED’s and CFL’s if you put a resister in one of the lights. There is a thread on here with photos and instructions for installing one in a can lighting. I like these because you can just replace the main switch on a 3 and 4 way circuit and they work great. I also use the CA3000 but they are hard to find, they now recommend the Evolve On/Off switch at AutomatedAutolet.com
Security System: You have the right idea with the DSC system and the EVL-3 board connected to the network. I did this in about 30 minutes and vera picked up ever sensor on the system for doors/windows/motion and it allows me to remotely arm/disarm my system, including having Vera Disarm the alarm when my kids enter their PIN number on the Yale lock on the front door. Be sure to have them put in sensors for the Garage Doors as well. Then all you have to do is put a Z-Wave receptacle for the garage door opener and wire it to a 110v relay and to the garage door opener contacts. You can then use the Garage Door module in the App Store to control your garage door using the Receptacle to pulse the power to the relay and you can see if the door is open by using the sensors for the garage door through the alarm system.
Door Locks: I use the Yale Deadbolt locks, they work great. They now have a new one that doesn’t have a key whole at all only a number pad which I feel is actually safer. I have used 4 of these and the batter life is great, should last you at least 6 months if not more before it hits the 50% alert mark.
Overall I have had a blast with Vera, I stated with a Vera Lite, Thermostate and a deadbolt and it has grown each month. That is one of the best parts of doing it this way, you don’t have to lay down $5k+, you can start and just add a little each month until you get what you like. With each project you get more and more confidence to try another one. My next one is using the INSTEON FanLinc to control my fans better.
My Goal is to have every light/fan/door/window automated in this house before I sell it in a couple of years. As a RELTOR I can tell you, this will defiantly be a home buyers remember.[/quote]
Thank you! A couple of follow-up questions, if you don’t mind.
What Trane thermostat do you use?
Can I use the Intermatic CA600 dimmers as switches, too? For the 6 for $99 price, it’s still less expensive than anything else out there.
Is there a scene controller that works with the Intermatic dimmers? I see they have an Intermatic scene controller but it just allows for 1 scene (CA5100). I’d like something that allows for multiple scenes. And if it worked with the INSTEON FanLinc, that’d be great, too.
Which Yale lock do you recommend? And is there a hardwired version? Then I don’t have to worry at all about batteries, right?
Thanks again!!!
