Happy New Years everyone. I’m back and hoping everyone had plenty of rest and relaxation !
My resolution is to dust off this rPi2 and start testing again… Here’s what I have on my list of things to-do !
[1] Sonos plugin using multiple Sonos devices. One Sonos works fine, multiples cause all Sonos systems to cease operation.
This was based on my latest test on Sunday.
Need to load device(s) on clean start to reduce log data.
[2] Door Locks. This one is strange and I think I might know why but need logs to show what it’s doing.
Watched Variable is (UserID~=“0”). UserA after UserB triggers scene. UserB after UserA triggers scene. UserX after UserY won’t trigger scene.
Need to create a scene on clean start to reduce log data.
[3] Data persistence (I’m looking for a flexible method to store and recall variables); including across restarts.
Data Yours possibly ? I need to read up on this as I’ve never used this plugin but it appears to store to a database.
Use case. Device A stores current value, power outage/restore resets Device A to default. Recall Device A and restore to previous state.
[4] Instant status from Vera devices to openLuup. Right now I’m just executing the openLuup scene from Vera for certain things (e.g. door bell).
Currently a ‘want’ rather than a ‘need’ - well at the moment at least…
Can be accomplished (work around) by calling openLuup scene from Vera.
[5] Philips Hue, there numerous bridge updates and the relationship of bridge to Hue plugin (via MCV).
I need to load the latest plugin (via MCV), grab the latest bridge (2.0) and do some unit testing to see how openLuup reacts.
We will lose support for bulbs that aren’t Philips Hue, at least via this plugin.
[6] Honeywell Plugin refactored by Mikee (a big thanks for all his hard work and for taking over this plugin).
Installs clean (3 thermostats) with no adjustment whatsoever. However after 24 hours this does cause openLuup and AltUI to freeze (but the PID’s are still active).
Need to investigate why, possibly attempt to use the AltUI debug feature.
Both logs just freeze at the same message, no errors…
[7] Luup.is_night()
This might already exist in a different form (syntax) but I’m not aware of how to use this within a scene on openLuup.
Once I’m passed all of this I’ll start on my alarm system using the DSC plugin. This will be quite a bit of work as my house hasn’t had a functional panel in years so I’m basically tearing out everything but the wires for the wired sensors. Should be pretty cool !
