Hello everyone,
Attached are the Device and implementation files for the BigAssFan Haiku K3150-AI Ceiling Fan.
[url=http://www.bigassfans.com/]http://www.bigassfans.com/[/url]
The codes allow full control over the fan with Vera and the SQBlaster Plugin
[ul][li]Upload both files via Vera → Apps → Develop Apps → Luup files[/li]
[li]Create a new device with the uploaded Device and Implementation files Vera → Apps → Develop Apps → Create device → Upnp Device Filename = D_SQdev7016046.xml, Upnp Implementation Filename = I_SQdev7016046.xml[/li]
[li]Refresh[/li]
[li]Go to the new Device and select the desired SQBlaster Channel for the Fan[/li][/ul]
The advanced option under Automation will now allow you to control the fan.
Following functions are included (Remote Control button = Vera Name):
[ul][li]Power On/Off = PowerToggle[/li]
[li]Fan Speed Up = SpeedUp[/li]
[li]Fan Speed Down = SpeedDown[/li]
[li]Woosh = BreezeMode[/li]
[li]Sleep = Sleep[/li]
[li]Timer = Timer[/li]
[li]Clear = Clear[/li]
[li]Light On/Off = Light[/li]
[li]Light Up = BrightnessUp[/li]
[li]Light Down = BrightnessDown[/li][/ul]
As I have a fan without light and I’m not able to test the light function, please feedback in case there are issues.
Enjoy
