HA14WD Showing Temp?
One of my HA14WD is reporting to Vera a Current Temperature. I was unaware if that could actually happen, and didn’t know if anyone else seen something like that before? It’s weird because I have about 15 of the same model, and same firmware switches in the house, and it’s the only one reporting a temp. I also have a WDTC-20 the next room over, but it is reporting a temperature of a degree cooler, so I don’t think it’s just picking up a reading off of that device.
Did the Ha14WD just start reporting temperature Did you try deleting the device in question and re-adding it to the network?
Just started, after I upgraded to the .899 build. . .
