Yay! I think I found the issue. It appears that when it fails, the Echo is looking for Groups on the ha-bridge. This is something it doesn’t look for when it succeeds. ha-bridge apparently doesn’t implement the “groups” URL for discovery, and the Echo is getting a 404 not found which causes the whole thing to fail.
No idea why the Echo arbitrarily looks for this URL when you add a certain number of devices. It’s interesting to note that when it succeeds, it looks for the “/api/hm3JnxYjJAKVDx8OkGQZwk1UKTwslVGKn0or5N29/lights” twice. But when it fails, it looks for the /lights URL only once, and then the /groups/0 URL. I ran the JSON through a JSON->CSV converter to see if there was anything in the failed one that was glaringly different from the successful one, and I didn’t find anything. It seems like it’s totally dependent on the number of “lights” that it finds.
The fix should be to make ha-bridge respond to the /groups/0 request with valid data.
See the screenshot of the relevant part of the conversation. Also, here’s reassembled HTTP conversation between the Echo and ha-bridge:
[code]GET /description.xml HTTP/1.1
Host: 10.4.4.4:8080
Accept: /
HTTP/1.1 200 OK
Date: Mon, 11 Jul 2016 22:05:17 GMT
Content-Type: application/xml; charset=utf-8
Transfer-Encoding: chunked
Server: Jetty(9.3.z-SNAPSHOT)
504
<?xml version="1.0" encoding="UTF-8" ?>
1
0
http://10.4.4.4:8080/
urn:schemas-upnp-org:device:Basic:1
HA-Bridge (10.4.4.4)
Royal Philips Electronics
http://www.bwssystems.com
Hue Emulator for HA bridge
Philips hue bridge 2012
929000226503
http://www.bwssystems.com/apps.html
0017880ae670
uuid:88f6698f-2c83-4393-bd03-cd54a9f8595
(null)
(null)
(null)
(null)
(null)
index.html
image/png
48
48
24
image/png
120
120
24
0
GET /api/hm3JnxYjJAKVDx8OkGQZwk1UKTwslVGKn0or5N29/lights HTTP/1.1
Host: 10.4.4.4:8080
Accept: /
HTTP/1.1 200 OK
Date: Mon, 11 Jul 2016 22:05:18 GMT
Content-Type: application/json; charset=utf-8
3C5D
{“816426751”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Bath Vanity”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“816426751”,“swversion”:“66012040”},“1264089409”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Front Door”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1264089409”,“swversion”:“66012040”},“144418120”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Entry Chandalier”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“144418120”,“swversion”:“66012040”},“788097137”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Wall Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“788097137”,“swversion”:“66012040”},“1934258348”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Turn off all Interior Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1934258348”,“swversion”:“66012040”},“1411958924”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Center Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1411958924”,“swversion”:“66012040”},“2113043789”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Front Sconces”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“2113043789”,“swversion”:“66012040”},“508879508”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Library Center Light”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“508879508”,“swversion”:“66012040”},“571431583”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Shelves”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“571431583”,“swversion”:“66012040”},“1327197244”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Screen Porch”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1327197244”,“swversion”:“66012040”},“1843645299”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Basement Hall”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1843645299”,“swversion”:“66012040”},“1918184196”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Lock All Doors”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1918184196”,“swversion”:“66012040”},“1238052402”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Open Single Garage Door”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1238052402”,“swversion”:“66012040”},“559465269”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Office Ceiling”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“559465269”,“swversion”:“66012040”},“901498435”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Kitchen Counter”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“901498435”,“swversion”:“66012040”},“575342473”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Under porch light”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“575342473”,“swversion”:“66012040”},“1040554235”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Bath Tub”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1040554235”,“swversion”:“66012040”},“1641256611”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Loft Stairs”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1641256611”,“swversion”:“66012040”},“951342192”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Guest Room Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“951342192”,“swversion”:“66012040”},“932677823”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Library Recess Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“932677823”,“swversion”:“66012040”},“1788047618”:{“state”:{“on”:true,“bri”:255,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Office Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1788047618”,“swversion”:“66012040”},“1391005699”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Service Door”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1391005699”,“swversion”:“66012040”},“1520172996”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“West Flood Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1520172996”,“swversion”:“66012040”},“850787516”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Entry”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“850787516”,“swversion”:“66012040”},“1936090347”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Basement Stairs”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1936090347”,“swversion”:“66012040”},“898624118”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Theatre Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“898624118”,“swversion”:“66012040”},“1549909653”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Garage Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1549909653”,“swversion”:“66012040”},“1328710977”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Kitchen Undercabinet”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1328710977”,“swversion”:“66012040”},“833563335”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Plants”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“833563335”,“swversion”:“66012040”},“1438169905”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Entry Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1438169905”,“swversion”:“66012040”},“1135938122”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Powder Room Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1135938122”,“swversion”:“66012040”},“117021045”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Hall Lights”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“117021045”,“swversion”:“66012040”},“28099882”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Buffet Sconces”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“28099882”,“swversion”:“66012040”},“2017113592”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Toilet”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“2017113592”,“swversion”:“66012040”},“1073249371”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Office Undercabinet”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1073249371”,“swversion”:“66012040”},“1878274554”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Kitchen Island”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1878274554”,“swversion”:“66012040”},“789426511”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“789426511”,“swversion”:“66012040”},“456071364”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Bridge”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“456071364”,“swversion”:“66012040”},“1140031584”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Buffet Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1140031584”,“swversion”:“66012040”},“1585890219”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Shower”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1585890219”,“swversion”:“66012040”},“1858469909”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Sitting Room Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1858469909”,“swversion”:“66012040”},“1261974709”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Dining Sconces”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1261974709”,“swversion”:“66012040”},“1256267403”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Asas Bedroom”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1256267403”,“swversion”:“66012040”},“1008282358”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Outside back”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1008282358”,“swversion”:“66012040”},“395693925”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Attic Fan”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“395693925”,“swversion”:“66012040”},“1838559091”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Asas Bedroom”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1838559091”,“swversion”:“66012040”},“16771416”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Bathroom Fan”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“16771416”,“swversion”:“66012040”},“837603318”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Parkers Room”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“837603318”,“swversion”:“66012040”},“1061214409”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Mud Room”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1061214409”,“swversion”:“66012040”},“811327330”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Close All Garage Doors”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“811327330”,“swversion”:“66012040”},“586184677”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Self Destruct”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“586184677”,“swversion”:“66012040”},“1578346452”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Loft Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1578346452”,“swversion”:“66012040”},“1737890371”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Fireplace Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1737890371”,“swversion”:“66012040”},“1807515451”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Master Bay Window”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1807515451”,“swversion”:“66012040”},“205557296”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Test Chime”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“205557296”,“swversion”:“66012040”},“497159847”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Open Double Garage Door”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“497159847”,“swversion”:“66012040”},“701547911”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Living Room Sconces”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“701547911”,“swversion”:“66012040”},“1086858532”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Table Recess”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1086858532”,“swversion”:“66012040”},“1598717415”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Buffet Sconces”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1598717415”,“swversion”:“66012040”},“1305488371”:{“state”:{“on”:false,“bri”:0,“hue”:0,“sat”:0,“effect”:“none”,“ct”:0,“alert”:“none”,“reachable”:true},“type”:“Dimmable light”,“name”:“Theatre Ceiling”,“modelid”:“LWB004”,“manufacturername”:“Philips”,“uniqueid”:“1305488371”,“swversion”:“66012040”}}
0
GET /api/hm3JnxYjJAKVDx8OkGQZwk1UKTwslVGKn0or5N29/groups/0 HTTP/1.1
Host: 10.4.4.4:8080
Accept: /
HTTP/1.1 404 Not Found
Date: Mon, 11 Jul 2016 22:05:24 GMT
Cache-Control: must-revalidate,no-cache,no-store
Content-Type: text/html;charset=iso-8859-1
Content-Length: 368
Error 404
HTTP ERROR: 404
Problem accessing /api/hm3JnxYjJAKVDx8OkGQZwk1UKTwslVGKn0or5N29/groups/0. Reason:
Not Found
Powered by Jetty:// 9.3.z-SNAPSHOT
[/code]
