Version 2.1 is available.
It is now totally hands free. It can be run in the background while other android apps are running in the foreground.
Use OK Google … then Open Listener to start H@l
When H@l is listening … you can use “Stop Listening” to tell it to not try to interpret commands.
The “Stop Listening” command can be user customized.
You can also have H@l stop listening at a specified time after the last successful command.
To get H@l’s attention … just say “OK Vera”. This phrase can also be customized by the user.
To return to standard OK google recognition … say “Goodbye” … you can always start commanding Vera again with “OK Goole” then “Open Listener”.
[hr]
The speech recognition configuration files are now visible, and can be customized, so people can attempt to add new phrases to activate Vera Device commands.
[hr]
Full Open Mike Support will require a license after 30 days.
