H.264 IP camera operation
Hello Everyone,
New to the forum and have ordered a Vera3 and wanted to know if Vera3 UI5 will work with the new H.264 MPEG-4 codec IP cameras out there such as the new Foscam FI8608 or other?
I want to connect four H.264 IP cameras and run at least 640x480 resolution/25 to 30 FPS…Can I get that to work without much trouble?
idem
i plan to buy one too and would like it to run 1280x1024 resolution as it wont be a benefit to me since the thing is expensive and my software ip-cam can do 1024x768 res.
It should do as I have a Panasonic one that can output either H.264 or MJPEG, and it seems to be OK when set to H.264
Strangely–
What specific Panasonic camera do you have working? and how?
 Don
[quote=“Don Diego, post:4, topic:170819”]Strangely–
 Don[/quote]
A BL-C210, and I got it working without jumping through hoops.
