Grouping door locks for a single code
I?ve got two schlage z-wave door locks. One on the security door and one on the main door. Is there anyway to group them so that when I create codes and associated schedules I only have to do it once For both locks? I tried to create scenes where if one locks or unlocks it locks or unlocks the other but had unreliable results.
In the pin code screen on ui7 you should be able to push codes to multiple locks at once. I don’t think you can set the pin restrictions en masse though.
