Great alternative to USB->serial adapters!
Someone suggested I look at one of these:
http://www.wiznet.co.kr/sub_modules/en/product/Product_Detail.asp?cate1=5&cate2=8&cate3=0&pid=1104
I bought one from semiconductorstore.com. It took awhile to ship, because they were not stocking them and had to ship it from Korea.
In any case, I have several devices that are serial only that I want to control with the Vera. USB->Serial adapters are kind of sucky, and they don’t always bind to the same /dev/ entry upon reboot. This thing took me 5 mins to set up.
The basic idea is that it has an IP, and you set up a TCP port for each serial port. For example, 10.2.2.2:2001 might be serial port 1, 10.2.2.2:2002 might be serial port 2, and so on. It can operate over UDP also, but I haven’t tried that. It can also act as a client, so upon boot, it will try to initiate the connection to a remote server. Each serial port can be set totally independent as far as settings go.
I’m planning on adding IP support to my LiteTouch plugin, and using this to connect. And I’m making a plugin for the Monoprice Multizone audio system which will have IP support.
Anyway, this thing is neat. And at $95, it’s well worth it.
Thanks for the info
1985 called. They said they wanted their terminal server back. ;D
I’m glad you found what you needed. The price is very good for new.
[quote=“Z-Waver, post:3, topic:179416”]1985 called. They said they wanted their terminal server back. ;D
I’m glad you found what you needed. The price is very good for new.[/quote]
Yep! I have an old Cisco 2500 w/ the serial breakout cable somewhere, but I have enough large things sucking down electricity and making tons of fan noise. I figured this was a good alternative. Everything else I found was over $400.
I’ve bought the 1-port (WIZ-110SR) and 2-port (WIZ-125SR) versions of these from the Wiznet directly in the past, since their US presence is just down the road in San Jose, CA.
Typically they arrived quickly, but my last order was back in 2011 so things might have changed since then. This is their store address (no affiliation, etc):
http://www.shopwiznet.com/modules/serial-ethernet-modules?limit=all
The 1-Port versions are also available from Sparkfun if you want something a little closer. The Brultech ECM lads use a variant of this in their power monitoring stuff (a soldered/headered version) and they’re all very reliable. For the smaller models, you can power them from old USB power adapters (iPhone, etc) which makes them very handy for tight locations.
I use the dual one to control a couple a Monoprice matrix switches, and they work great on USB power.
