I’m a bit new, but i’m pretty sure my issue isn’t user error. I’ve been able to add the gocontrol siren from the “security suite”. I can manually turn it on and off from my vera home page and app(iOS). I initially bench-tested it, but later read that thats a no-no. After “unmounting” it and re-mounting it while it was in the location it would remain, I expected the random siren’ing to stop. But alas, it turned on when a nearby motion sensor was tripped (a sensor that has no scenes with the siren, and is not the same brand)
Any suggestions (including sending it back for a refund)?
Thanks!
croen, check out your settings in Modes. Most likely it is set to go off when motion is sensed.
Just found this thread, I was having the same problems and didn’t even think about looking in Modes! Thanks Marc!
