Here is the promised code. This is the “library” file, which need to be uploaded:
ihDimmerList = {}
ihSwitchList = {}
function ihSetDimmers(slaveIds, value)
for i, deviceId in ipairs(slaveIds) do
luup.call_action("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget", { newLoadlevelTarget = tostring(value)}, deviceId)
function ihSetSwitches(slaveIds, value)
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget", {newTargetValue = tostring(value)}, deviceId)
function ihFollowDimmer (lul_device, lul_service, lul_variable, lul_value_old, lul_value_new)
ihSetDimmers(ihDimmerList[lul_device], lul_value_new)
function ihFollowSwitch (lul_device, lul_service, lul_variable, lul_value_old, lul_value_new)
ihSetSwitches(ihSwitchList[lul_device], lul_value_new)
function ihInstallWatchers(dimmerList, switchList)
ihDimmerList = dimmerList
ihSwitchList = switchList
for i,lst in pairs(dimmerList) do
luup.log("Install dimmer watcher for: " .. tostring(i));
luup.variable_watch("ihFollowDimmer", "urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", i)
for i,lst in pairs(switchList) do
luup.log("Install switch watcher for: " .. tostring(i));
luup.variable_watch("ihFollowSwitch", "urn:upnp-org:serviceId:SwitchPower1", "Status", i)
Yes, followXX functions can be merged in one, but MiOS guys made some things “nice” like newLoad_l_evelTarget, which corresponds to LoadLevelTarget, the need to have Target and Status here, etc. And also - variable_set() didn’t work for me. This is used by putting this in the startup code:
require("THE_LUA_FILENAME")
ihInstallWatchers({ [4] = {57, 71}, [49] = {60, 72, 18, 20} }, { [3] = {59}, [8] = {61} })
The idea is - [MASTER_DEVICE_ID] = {LIST_OF_SLAVE_DEVICE_IDS}. Not a big deal, indeed.
For this Target <-> Status not being a bug, Garett - yes, I understand you and why is this happening. My point was, that a change in this device - although controlled from elsewhere - DOES trigger a scene, so theoretically Vera can obtain that status-change and reflect it in its internal variables, like LoadLevelTarget, but it doesn’t.
joey52685, polling is not the only way for Vera to obtain data from devices, they can “push” their state to it and, to the best of my knowledge, it is done using same association mechanism. For example Fibaro dimmers/switches has a special association group (#3) for status updates, so every time a change happens, it notifies devices listed there. Actually, there can be ONE device, and Vera puts itself in that list. Other devices, like Vitrums that I need to get working with dimmer, have another association channels and concept of updates. That’s my understanding so far
