Not sure what I’m doing wrong…
under
Edit Startup Lua I have
myLua = require("L_MyLUACode")
I upload a file under Luup files named L_MyLUACode.lua
that contain
[code]module(“L_MyLUACode”, package.seeall)
local PLUGIN_VERSION = ‘1.01’
local myLua_DEBUG_MODE = true
– A jump table to the various functions used by the scenes.
– Call as shown below in each scene LUUP section, where xx is the scene number:
– return myLua.executeSceneNumber(xx)
sceneFunctions = {}
local function createSceneNumberTable()
– make sure demonstration scene numbers do not conflict with yours
sceneFunctions[26] = DSC_-Partition1-Home_Entry
sceneFunctions[12] = DSC-Partition1-_Disarm
–sceneFunctions[201] = Lounge_AV_Radio
–sceneFunctions[202] = Lounge_Standard_lamp_on_for_10_mins
–sceneFunctions[203] = Office_Printer_on_for_30_mins
–sceneFunctions[204] = Unused_TEST
local function debugScenes(textParm)
if myLua_DEBUG_MODE then
local text = ‘’
local theType = type(textParm)
if theType == ‘string’ then
text = textParm
else
text = 'type is: '…theType
luup.log('My Lua ver ‘…PLUGIN_VERSION…’ debug: '…text, 50)
local function globaliseTheseFunctions()
– Stick all the luup.call_delay targets into the Global namespace table.
– Otherwise they are not visible to luup.call_delay and won’t be executed.
– We always prefix them with ‘myLua_’ to help avoid Global namespace collisions.
local function f_sendLog()
– mda: wrap RexBeckett’s code with a few tweaks in a function so i can call it with a delay
– Keep snapshots of LuaUPnP.log
local snapSecs = 360 – Seconds of log to keep in snapshot.
local snapNum = 3 – Total number of snapshots to keep.
local baseFile = “/www/logsnap”
local snapFile = baseFile … “1.txt”
local snapVar = “Vera Luup Restart Log”… “\n” – mda: initialize the variable to email
– Rename the snapshot stack
if snapNum > 1 then
for i=snapNum-1,1,-1 do
os.rename(baseFile … tostring(i) … “.txt”, baseFile … tostring(i+1) … “.txt”)
– Take snapshot of current log
local dt = {}
local cut = os.time() - snapSecs
local snapF,snapE = io.open(snapFile,“w+”)
if snapF ~= nil then
local foundcut = false
for line in io.lines(“/tmp/log/cmh/LuaUPnP.log”) do
if not foundcut then
mStr,dStr,yStr,hhStr,mmStr,ssStr = string.match(line,“^%d%d.-(%d+)/(%d+)/(%d+)%s(%d+):(%d+):(%d+)”)
if mStr ~= nil then
dt.month = tonumber(mStr)
dt.year = tonumber(yStr) + 2000
dt.day = tonumber(dStr)
dt.hour = tonumber(hhStr)
dt.min = tonumber(mmStr)
dt.sec = tonumber(ssStr)
tstamp = os.time(dt)
if (tstamp >= cut) then foundcut = true end
if foundcut then
snapF:write(line … “\n”)
snapVar = snapVar .. line .. "\n" -- mda: add this log line to the variable that will be emailed
-- Following line stops snapshot at point of crash.
if string.find(line,"LuaUPnP Terminated with Exit Code:") ~= nil then break end
snapF:close()
– mda: clean up the log text in the variable before emailing it; i bet this could be done with a gsub table if i knew how to do that
snapVar = snapVar:gsub(“%[1;00m”,“”)
snapVar = snapVar:gsub(“%[0m”,“”)
snapVar = snapVar:gsub(“%[35;1m”,“”)
snapVar = snapVar:gsub(“%[33;1m”,“”)
snapVar = snapVar:gsub(“%[33;1”,“”)
snapVar = snapVar:gsub(“%[32;1m”,“”)
snapVar = snapVar:gsub(“%[34;1m”,“”)
snapVar = snapVar:gsub(“%[36;1m”,“”)
snapVar = snapVar:gsub(“%[7;36m”,“”)
luup.call_action(“urn:richardgreen:serviceId:VeraAlert1”, “SendAlert”, {Message = snapVar, Recipients = “SMTP-Mail”}, vera_alerts_device) – mda: email the snapVar variable contents using Vera Alert
end – function
local function initialiseMyLuaCode()
– luup.call_delay( ‘f_sendLog’, 20) – mda: delay it (to give Vera Alerts time to initialize?)
– debugScenes(‘testing’)
– createSceneNumberTable()
local function DSC_-Partition1-Home_Entry()
– Scene 26
debugScenes('DSC-Partition1-_Home_Entry is starting’)
myLua_sonosSay("Bon retour, je pr?pare la maison.",15,"Living Room,Kitchen")
debugScenes('DSC_-_Partition1_-_Home_Entry is finished')
local function DSC_-Partition1-Disarm()
– Scene 12
debugScenes('DSC-Partition1-_Disarm is starting’)
myLua_sonosSay("Le syst?me d'alarme est d?sarm?.",15,"Living Room,Kitchen")
debugScenes('DSC_-_Partition1_-_Disarm is finished')
function executeSceneNumber(sceneNumber)
– example usage: return executeSceneNumber(xx)
if (sceneNumber == nil)
then
debugScenes(‘sceneNumber is nil’)
return false
local roomDescription = luup.rooms[luup.scenes[sceneNumber].room_num] or 'unnamed room'
debugScenes('executing scene '..tostring(sceneNumber)..': "'..luup.scenes[sceneNumber].description..'" in room: "'..roomDescription..'"')
if (sceneFunctions[sceneNumber])
then
local result = sceneFunctions[sceneNumber]()
if result then
debugScenes('rest of scene '..tostring(sceneNumber)..' was executed')
else
debugScenes('rest of scene '..tostring(sceneNumber)..' was aborted')
return result
else
debugScenes('no associated function found for scene number: '..tostring(sceneNumber))
return false
function checkTime(time1,time2)
local pStart = time1 – Start of time period
local pEnd = time2 – End of time period
local allow = true – true runs scene during period, false blocks it
local hS, mS = string.match(pStart,“(%d+)%:(%d+)”)
local mStart = (hS * 60) + mS
local hE, mE = string.match(pEnd,“(%d+)%:(%d+)”)
local mEnd = (hE * 60) + mE
local tNow = os.date(“*t”)
local mNow = (tNow.hour * 60) + tNow.min
if mEnd >= mStart then
return (((mNow >= mStart) and (mNow <= mEnd)) == allow)
else
return (((mNow >= mStart) or (mNow <= mEnd)) == allow)
function checkSwitch(dID, allow)
–local dID = 66 – Device ID of your Z-Wave Switch
–local allow = true – true runs scene if switch is on, false blocks it
local status = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”,“Status”,dID)
return ((status == “1”) == allow)
function checkWWN_status()
local status = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”,“ModeStatus”,50)
return (status)
function sonosSay(text2say, dID, zones)
status = checkTime(“23:30”,“08:00”)
if (status == true) then volume=20
else volume=40
if (zones == “”) then
–debugScenes(‘SONOS is talking…’)
luup.call_action(“urn:micasaverde-com:serviceId:Sonos1”, “Say”,
{Text=text2say, Language=“fr”, Volume=volume},
dID)
else
{Text=text2say, Language=“fr”, Volume=volume, SameVolumeForAll=true, GroupZones=zones},
dID)
initialiseMyLuaCode()[/code]
But I’m unable to call the global function from anywhere. I test my function in “local” mode to make sure my code is good. Got no error at all.
The problem is to call the “global” function!
I try
sonosSay(“This is a test”,18)
and
myLua.sonosSay(“This is a test”,18)
and both of them are not working.
