getting "disabled|not-mounted" after clicking "Store logs on USB device"
I’m getting “disabled|not-mounted” message on the screen after clicking “Store logs on USB device” (in UI6/Setup/Logs/Store logs on USB device), and then also the follow-up message “WARNING: The usb drive will be erased. Wait 20 minutes after clicking OK”
If I wait the 20 minutes the USB status on this page is still “USB status - Disabled - Not mounted”. After rebooting same. Not sure if it helps however when I run “dmesg” on the VeraLite when the USB is plugged in, and then again after removed I see this…
Any advice? Want to be able to do Verbose Logging, but need to get the “stores logs on USB” working first.
Unplug root@MiOS_35202858:/dev# dmesg usb 1-1: USB disconnect, address 3
PlugIn
usb 1-1: new high speed USB device using rt3883-ehci and address 4
scsi2 : usb-storage 1-1:1.0
scsi 2:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 15133248 512-byte logical blocks: (7.74 GB/7.21 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
sd 2:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
I am having EXACTLY the same problem. I have tried with two different USB stick, tried both with a totally empty stick (no partition), one with a single primary partition (unformated) with a FAT formated partition.
The USB sticks I tried was both quite small (about 400 MB) but that should be enough for quite a lot of logs I figured…
I wish MiCasaVerde could provide much more detailed information about this (and even more that the process was more self explanatory of course)…
