Getting data from a sensor in a file
Time to adjust something here :slight_smile:
Writing these temperatures in a file works very well.
Unfortunately, with the blue iris programm you can only have 9 macro’s 9 in my case 9 different temperature overlays.
I use this code now that every temperature sensor will have his own .txt file
[code]local devID = 128
local temperature = luup.variable_get(ā€œurn:upnp-org:serviceId:TemperatureSensor1ā€,ā€œCurrentTemperatureā€,devID)
local file = io.open(ā€œ/www/blueiris/oatemp.txtā€, ā€œwā€)
file:write(temperature … ā€œ\176Cā€)
file:close()
local devID = 43
local file = io.open(ā€œ/www/blueiris/bathroomtemp_up.txtā€, ā€œwā€)
file:close()
local devID = 48
local file = io.open(ā€œ/www/blueiris/bathroom_main.txtā€, ā€œwā€)
file:close()
local devID = 189
local file = io.open(ā€œ/www/blueiris/Vorlauf.txtā€, ā€œwā€)
file:close()
local devID = 186
local file = io.open(ā€œ/www/blueiris/Heizung.txtā€, ā€œwā€)
file:close()[/code]
Is it possible to write all these variables in 1 files, and in a specific order, (below each other) ,like:
19,9 ?C
21 ?C
60 ?C
etc.
many thanks,
Cor
19,9 ?C
21 ?C
60 ?C
Yes that is easy to do:
devID = 43
devID = 48
devID = 189
devID = 186
file:close()[/code]
NICE!!! ;D
To makr it near perfect , After every variable there is now this " ā€œ\176Cā€ code to make it de Celcius character. Is it possible to have before a variable the name of the variable than the variable , than the Celcius sign?
Like this:
Bathroom xx.x ?C
Thanks,
Cor
No problem. Just adjust the text in the following:
file:write("Outside " … temperature … ā€œ\176Cā€)
devID = 43
file:write("Bath Main " … temperature … ā€œ\176Cā€)
devID = 48
file:write("Bath Up " … temperature … ā€œ\176Cā€)
devID = 189
file:write("Vorlauf " … temperature … ā€œ\176Cā€)
devID = 186
file:write("Heizung " … temperature … ā€œ\176Cā€)
file:close()[/code]
Hi RexBecket,
I just changed the LUUP code , but there is somewhere something wrong , the variables are not written below each other on the next line , but next to each other.
Like this:
Ambient 20?CBuffer 43?CBoiler 40?CWater 34?CBathroom Upstairs 12?CBathroom Downstairs 14?C
This is the LUUP code:
[code]local devID = 186
local file = io.open(ā€œ/www/blueiris/heating.txtā€, ā€œwā€)
file:write("Ambient " … temperature … ā€œ\176Cā€)
devID = 187
file:write("Buffer " … temperature … ā€œ\176Cā€)
devID = 188
file:write("Boiler " … temperature … ā€œ\176Cā€)
devID = 189
file:write("Water " … temperature … ā€œ\176Cā€)
devID = 43
file:write("Bathroom Upstairs " … temperature … ā€œ\176Cā€)
devID = 48
file:write("Bathroom Downstairs " … temperature … ā€œ\176Cā€)
file:close()[/code]
Is it possible to have it written on seperate lines?
Like this?
Ambient 20?C Buffer 43?C Boiler 40?C Water 34?C Bathroom Upstairs 12?C Bathroom Downstairs 14?C
Many thanks,
Cor
Sure. Just add a newline character (\n) at the end of each output string. So replace ā€œ\176Cā€ with ā€œ\176C\nā€ in each file:write(…) statement.
Cool ;D,
It’s working perfect, many thanks!
Cor
A little update,
I would also like to add the humidity. I tried to add this in the LUUP code , but it didn’t work.
[code]local devID = 37
local file = io.open(ā€œ/www/blueiris/Living_room.txtā€, ā€œwā€)
file:close()
local devID = 40
local file = io.open(ā€œ/www/blueiris/corridor.txtā€, ā€œwā€)
file:close()
local devID = 91
file:write("Ambient: " … temperature … ā€œ\176C\nā€)
devID = 92
file:write("Buffer: " … temperature … ā€œ\176C\nā€)
devID = 93
file:write("Boiler: " … temperature … ā€œ\176C\nā€)
devID = 87
file:write("Bathroom Upstairs: " … temperature … ā€œ\176C\nā€)
devID = 78
file:write("Bathroom Downstairs: " … temperature … ā€œ\176Cā€)
devID = 79
temperature = luup.variable_get(ā€œurn:upnp-org:serviceId:TemperatureSensor1ā€,ā€œCurrentHumidityā€,devID)
file:write("Bathroom Downstairs: " … humidity … ā€œ\176Cā€)
file:close()[/code]
It is the bottom one which I would like to include with device # 79
Anyone sees what I am doing wrong?
This is certainly wrong…
devID = 79
temperature = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentHumidity",devID)
file:write("Bathroom Downstairs: " .. humidity .. "\176C")
You would need instead…
devID = 79
humidity = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel",devID)
…or something along those lines.
I haven’t checked the whole thing, there may be others.
You need to understand where the serviceIds and variable names come from. This would be a start: http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions
Super!
Thanks, It works now.
Understanding all the coding :o … but it makes more sense now.
Cor
Thanks @RexBeckett. I was looking for this info for some time. Can you also tell me how to fetch the time stamp along with the temperature info please ?
The documentation here:
http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_variable_get
Would tell you that all you need is:
devID = 79
humidity, tstamp = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel",devID)
However, this may not be reliable if the system has reloaded in the meantime.
Thanks @akbooer. It was really valuable information
Hello again ,
All was working very well … untill I updated the firmware this morning … :-
I got it partially working again , but wierdly enough 2 files are not working.
This is the complete Luup code which was working with the previous firmware:
file:close()
local devID = 40
file:close()
local devID = 117
local file = io.open(ā€œ/www/blueiris/garage.txtā€, ā€œwā€)
file:close()
local devID =212
local file = io.open(ā€œ/www/blueiris/OAT.txtā€, ā€œwā€)
file:close()
local devID = 212
local file = io.open(ā€œ/www/blueiris/heating2.txtā€, ā€œwā€)
file:write("Outside: " … temperature … ā€œ\176C\nā€)
devID = 40
file:write("Corridor: " … temperature … ā€œ\176C\nā€)
devID = 37
file:write("Living: " … temperature … ā€œ\176C\nā€)
devID = 117
file:write("Garage: " … temperature … ā€œ\176C\nā€)
devID = 228
file:write("Hobby: " … temperature … ā€œ\176C\nā€)
devID = 230
humidity = luup.variable_get(ā€œurn:micasaverde-com:serviceId:HumiditySensor1ā€,ā€œCurrentLevelā€,devID)
file:write("Hobby: " … humidity … ā€œ%ā€)
file:close()
local devID = 91
devID = 92
devID = 93
devID = 94
file:write("Radiator: " … temperature … ā€œ\176C\nā€)
devID = 87
devID = 88
file:write("Bathroom Upstairs: " … humidity … ā€œ%\nā€)
devID = 78
file:write("Bathroom Downstairs: " … temperature … ā€œ\176C\nā€)
devID = 79
file:write("Bathroom Downstairs: " … humidity … ā€œ%ā€)
file:close()
local devID = 228
local file = io.open(ā€œ/www/blueiris/Hobby.txtā€, ā€œwā€)
devID = 230
file:write("Humid: " … humidity … ā€œ%ā€)
file:close()[/code]
Now , 2 files will not create , this part which is at the bottom:
[code]local devID = 228
devID = 230
file:close()[/code]
And this part in the middle, here the file is created , but the file remains empty:
[code]local devID = 91
devID = 92
devID = 93
devID = 94
devID = 87
devID = 88
devID = 78
devID = 79
file:close()
[/code]
The device ID are still correct …
anyone has an idea why it does not want to write , the rest of the LUUP code , writing it’s files works fine.
Thanks,
Cor
…so what errors are shown in the log?
I downloaded the LUAupnp.log file ( That is the one you are referring to?)
I might have found the problem , But I have no idea what to do with this info:
08 01/16/17 18:45:48.624 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunScene <0x6f96 c520> 08 01/16/17 18:45:48.624 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6f96c520> 08 01/16/17 18:45:48.625 JobHandler_LuaUPnP::HandleActionRequest argument action=RunScene <0x6f96c520> 08 01/16/17 18:45:48.625 JobHandler_LuaUPnP::HandleActionRequest argument SceneNum=12 <0x6f96c520> 08 01/16/17 18:45:48.625 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.11006943929211022 <0x6f96c520> 08 01/16/17 18:45:48.625 Scene::RunScene running 12 Script write temperatures file <0x6f96c520> 01 01/16/17 18:45:48.641 GetLuaInterface can't find device type: 3/0x1d33860 str: 91 <0x6f96c520> 01 01/16/17 18:45:48.642 luup_variable_get interface 0x1d30bc0 args 3 <0x6f96c520> 01 01/16/17 18:45:48.642 LuaInterface::CallFunction_Scene Scene 12 failed [string "function event_4()..."]:62: attempt to concatenate local 'temperature' (a nil value) <0x6f96c520>
It says It can not find a device type… Very wierd since before the firmware update this morning it was working fine.
Thanks,
Cor
I’d hazard a guess that it’s having a problem with device #91… are you sure it’s there?
I think you found my problem ;D !!
The device is indeed gone! :o , It is a universal sensor with 5 temperature sensors, the names are gone , the id changed …crap!!!
Anyway , I now know what to do tonight! >:(
Many thanks,
Cor
Since a couple of days , it doesn’t work anymore.
I updated to the latest firmware , since than the folder www\blueiris was removed.
I created in winscp the folder again , and it seemed to be working. but it is not. it did work once or twice , but now nothing anymore , when I start the scene manualy , nothing is written to the files.
Anyone has an idea , maybe something wrong with the rights of the folder?
Attached a screenshot of winscp , below the Lua code from the scene . ( Lua code was not changed).
file:close()
local devID = 40
file:close()
local devID = 321
file:close()
local devID = 268
file:close()
local devID = 268
devID = 40
devID = 37
devID = 321
devID = 212
file:write("Gate electrics: " … temperature … ā€œ\176C\nā€)
devID = 228
devID = 230
file:close()
local devID = 91
devID = 92
devID = 93
devID = 94
devID = 87
devID = 88
devID = 78
devID = 79
file:close()
local devID = 228
devID = 230
file:close()[/code]
I think I found it …
Due to the firmware update a device was gone , after getting it back , it had a new device ID . After changing the Lua script with the correct device ID , it seems to be working again.
Cor
note to myself: Only do a firmware update on the first day of vacation to iron out all the errors in the following days.
