Get snapshot archive on phone
I setup my Foscam camera so that it takes snapshots each time a certain door alarm trips. I can see the pictures via the archive on the web UI5 interface. I can’t seem to find them via mobile app - either Vera Mobile or AutHomationHD. Any advice?
The api is not exposed for 3rd party apps to access the picture archive. It can only be accessed via the Vera interface.
  • Garrett
Ahh, ok, that sort of stinks but I’ll live with it :smiley:
You could via the dropbox plugin
[quote=“garrettwp”]The api is not exposed for 3rd party apps to access the picture archive. It can only be accessed via the Vera interface.
  • Garrett[/quote]
It seems that the Dropbox uploader call the URL. See copy of earlier post. Would this not be something that could be used by 3rd party apps?
[url=http://forum.micasaverde.com/index.php?topic=16518.msg174940#msg174940]Quote from: mikee123 on May 07, 2014, 11:48:15 pm[/url]
Is there a way to have a better quality picture uploaded to dropbox ? All the pictures uploaded are about 80kB in size, and therefore the picture lack resolution. I am using Foscam 8918W and a Foscam 9821W (HD)
Not sure maybe I should have posted this in the Foscam section too but did not want to double post
The way the uploader works is it gets the image that your Vera makes available through the http://server/port_3480/data_request?id=request_image&cam=... Unless that can be configured to give a higher res image, you won't get a higher res image stored in dropbox.
Martin
Verstuurd vanaf mijn Nexus 5 met Tapatalk
This only requests the current camera image and not the archive. There is no way to access the picture archive at this time.
  • Garrett
