Get dimm-status problem
In vera using Luup;
How can I get the last dimm-level from a Fibaro-dimmswitch when the light is off? I’ve tried to retrieve a value, then dimmed to an optional, to finally return to the past, but it is wrong here.
Can anyone help me please.
Thanks :slight_smile:
@zuuper,
Welcome!
Not sure if that’s possible (especially if the device was switched off through Vera), but you can send the dimmer level 255 to tell it to turn back on to the last level, rather than a set level (if this at all is what you are after).
I am looking for the function:
When I get up at night to several lights dimmed up lightly. After x minutes, they return to the same position as before.
If the light is in 100% when I turn the light button off, then when I get up at night it dimmed to 10%. After x minutes, the return to 100% dimm (as before) and turned off as it was before. This is because when I press the button in the morning, it remembers how it was set last.
I haven’t seen devices where you can pre-set the level, but as the Fibaro’s support instant status, perhaps a workaround is to try a Vera scene that will change the level (based on time of day), triggered by the switch being turned on?
