I wanted to create these two scenes, I was able to create the second one- it works perfectly, wondering if anyone has any experience in creating the below mentinoed first scene:
- Using Vera app, create a scene wherein trigger is : user exiting the defined premises, action should be ArmedInstant, so that there is no delay when there is a breach.
I created this scene, when I leave the assigned location nothing happens, also I had to use Arm option instead of ArmedInstant as the action becasue Iphone app does not gives advanced scripting for scenes.
Moreover when I manually go into device from app and manually hit the arm button after putting the code instead of executing arm action, it executes Stay action, this i believe is due to the fact that it is thinking no door was opened/closed so user is still in the premises, so instead of executing arm action it executes stay action, this is happening with DSC plug in only, EVL4 app happily executes Arm action even if no door is opened/closed, which means hardware defintely supports it, just not sure if Vera and DSC plug in supports it and how.
any help would be really appreciated.
Second scene i was able to succeffuly configure is that when i get back to premises it automatically disarms.
