GE Switch stop responding
Has anyone had a problem with a switch just stop accepting wave commands? I have a switch that has been working for the past 2 months, today I noticed it didn’t turn off automatically like it used to. I went to Vera and switched the light off and even though vera showed the command successfully sent to the switch the switch did not respond. I can manually switch it on and off at the switch itself but nothing seems to work. Going to try excluding it and re adding it but curious if anyone has experienced this before?
First try rebooting the switch. Pull the air-gap tab out, wait a second, push back in. Then try it.
