I am installing 2 GE on/off relay switches to replace 2 existing toggle light switches. The first switch controls one inside light and the other switch controls 3 outside lights. Currently, all neutral wires are together using a wire nut in the back of the box. I understand that I need to use a neutral wire when connecting the new GE switches, but does it matter which one? Should I just connect each switch to the existing bundle of neutral wires or take specific neutral wires out of the wire nut and run to the switch?
Thanks!
