I have a pair of GE lamp modules (the kind you plug in) and under the previous UI, I went to the “advanced” section for each module, set parameter 29 to “1” and it enabled load sensing. When I updated to UI7 it reset the modules, and now when I go to advanced it requires 3 fields: “service” “variable” and “value” and will not add the parameter unless all three are filled out.
I have tried setting both “service” and “variable” to “29” ‘29’ and 29 and “value” to “1” ‘1’ and just 1 and no combination seems to work. Has anyone had luck getting the load sensing turned on?
