GE/Jasco Switch Failures
I am having a similar experience with my GE/Jasco switches (45609s I think). I installed them 4 years ago and now the z-wave portion on them is starting to fail on at least four of them. The local control is still working fine.
Seems like that is the life expectancy…
Just curious… did you pull the air gap switch and see if that helped?
Yes, air-gapped, power cycled, exclude/re-include. They just don’t have the build quality for the long term. I bought this particular one in '09 (date codes rock!).
On a side note, since I removed that dying GE dimmer, my Zwave mesh/response times has been super responsive. For future troubleshooting (ha!), worth doing a deep dive on individual devices that may not be communicating perfectly or is functioning in a quasi-configured state.
EDIT: I also happened to exclude my 2Gig alarm panel as a Secondary controller at the time I uninstalled the GE switch. (Never worked properly anyway.) So, I can’t be 100% certain that the failing switch was causing my intermittent Zwave problems, but it’s a pretty good bet based on observing the device’s behavior.
.//A.
