GE/JASCO parameters
Anyone have a complete list of all parameters for GE/JASCO switches and dimmers. I found this one at lowes: [url=https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi2to6lstzLAhWDSyYKHZD9DSQQFggpMAE&url=http%3A%2F%2Fwww.lowes.com%2Fpdf%2FirisMicrosite_GE_Dimmer_Switch.pdf&usg=AFQjCNG4SeWNqWX6_gZrR8FjRIRAoyHbpg&sig2=cbqeY0WCWCuBR10prsw82A]Redirect Notice , but i don’t think it is complete.
I have a couple of thee dimmers and i am trying to see if there is a way to re-set the power level to zero when the all-off command is issued. The wya they behave now, if the dimmer was set at 50% and the all-off command is sent, the next command starts from 50%. I really want them to start from zero. i assume this would be a parameter setting, but i can’t find one to do this.
I usually find that stuff here. I know the GE ones are also listed.
http://www.pepper1.net/zwavedb/
Edit: The parameters listed in the spec sheet match what the pepper1 db has. Looks like there isn’t a way to do it.
Great website. thanks for the link.
Guess i will try to code around the issue
Would be interested to know if you found a (code?) way to do this, as I want to do the same thing.
Steve
