GE Jasco 45603 doesn't light
I have just installed the mi casa light vera for the first time. Set up the GE light switch I bought and it installed without a problem. The light is plugged into the z-wave outlet, it lights manually if I turn on the light, but will not operate with the controller. If I use the controller to turn on the light, I hear the switch click, but the light doesn’t come on. It doesn’t come on if I hit the manual button either (which I think is the button in the middle of the switch.) Any ideas? If it weren’t the first thing I installed, I would assume that the switch is bad!
Plug the light into the outlet on the other side of the 45603. Only one outlet is switched the other is always on.
