GE/Jasco 3 way dimmer wiring with incoming power at light
Hi. Newbie here, just starting out. I’ve searched the boards and youtube, but haven’t been able to find anything that matches my situation. I’m trying to install a GE/Jasco 3way dimmer kit for my hall light. Very simple, one light fixture, 2 switches. The best I can tell, the power comes into the light’s junction box. There is a wire from the light to switch #1 and then a wire from switch #1 to switch #2 (see the attached picture). Am I screwed here or what?
The circuit that you have pictured is not compatible with the GE/Jasco 3-way kit. But, you can still Z-Wave enable the circuit by using an in-wall microswitch installed at the light where the power comes in. See teh attached diagram.
