All of a sudden I’ve lost ability to control one of my GE/Jasco switches via my Vera Lite or physically at the switch itself. The blue LED is on though. When I try to manually configure or run a full system zwave heal, I get the error message: Unable to get any information on node. What else can I do to troubleshoot this problem? Is my switch toast?
I would try to power cycle it (turn off the power at the breaker). I had similar issues and that fixed the manual operation of the switch. I then had to exclude the switch from Vera and re-include it.
Thanks Trotsky40, I will try that and see what happens.
Happy camper here! Simply power cycling by turning the breaker off and on solved my above problem. I was lucky enough to not have to go through inclusion process.
