GE dimmer switch for a switched wall outlet?
I have an existing wall switch that controls half of a wall outlet where a lamp is plugged in. Can I wire a z wave dimmer switch in the old switches place? The old switch is connected to a black wire(top) and a red wire(bottom) only. Inside the box it looks like 3 romex cables, one of which also has the red wire. All the blacks are tied together all the whites are tied together and all the grounds. Any suggestions on wiring. When I wire it up just like the previous switch it doesnt work.
I would highly suggest you do not hook a dimmer to an outlet switch. In the event that something is accidentally plugged into the outlet that is not a dimmable light, it could damage it as well as cause a fire. Controlled outlets should only be used for on / off (relay) switches.
  • Garrett
OK if I were to hook up an on/off z-wave switch in that box how would I wire it?
You would wire it as per Page 5 of the switch’s manual.
Your outlet goes in place of the bulb(load) symbol in the diagram.
As @garretwp stated; do NOT use a dimmer switch to control an in-wall outlet. If you want Z-Wave dimming of a lamp or something at the outlet, use a dimmer module like the GE/Jasco 45602.
As @garretwp stated; do NOT use a dimmer switch to control an in-wall outlet. If you want Z-Wave dimming of a lamp or something at the outlet, use a dimmer module like the GE/Jasco 45602.[/quote]
Yeah that was my plan B
